AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Kenmore Heavy Duty 70 Series Washer Does Not Advance Cycle
Our Kenmore Heavy Duty 70 Series washer does not advance to the rinse or the spin cycle. Model 110 91278100.
When I move the cycle knob manually to rinse the washer agitate but stops and end of rinse cycle. It does not drain or continue. When the I move the cycle knob manually to spin not happens at all.
I should note that moving the knob to rinse or so in used to work occasionally.
I replaced the lid switch, motor coupler, and agitator dogs.
What should I try next?
The timer?
Is there a way to test to see if the timer is ok?
Or is there something else I should be troubleshooting?
Thank you for any advice!
Groups: Expert
1 user thanked fairbank56 for this useful post.
Washer Repair
