bdcs64
#1 Posted : Thursday, March 5, 2015 6:07:36 PM(UTC)
bdcs64
Our Kenmore Heavy Duty 70 Series washer does not advance to the rinse or the spin cycle. Model 110 91278100.
When I move the cycle knob manually to rinse the washer agitate but stops and end of rinse cycle. It does not drain or continue.
When the I move the cycle knob manually to spin not happens at all.
I should note that moving the knob to rinse or so in used to work occasionally.
I replaced the lid switch, motor coupler, and agitator dogs.
What should I try next?
The timer?
Is there a way to test to see if the timer is ok?
Or is there something else I should be troubleshooting?
Thank you for any advice!
fairbank56
#2 Posted : Friday, March 6, 2015 3:14:53 AM(UTC)
fairbank56
Groups: Expert
Sounds like a faulty timer. Timer can be returned if it does not fix the problem.
Whirlpool 661597 Timer - AppliancePartsPros.com
Eric
thanks 1 user thanked fairbank56 for this useful post.
bdcs64 on 3/28/2022(UTC)
