My Dryer trips the breaker on start-up. Placed it on the air only setting to isolate the heating element. It ran for 5-10 sec. then tripped the breaker. Any advice on what to check next or what could be doing this? It is my guess that it could be a ground of bad motor.
Originally Posted by: Mrvin  My Dryer trips the breaker on start-up. Placed it on the air only setting to isolate the heating element. It ran for 5-10 sec. then tripped the breaker. Any advice on what to check next or what could be doing this? It is my guess that it could be a ground or bad motor. Any advice would be appreciated.
