AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
whirlpool dryer trips breaker during cool down
whirlpool dryer trips circuit breaker during the cool down cycle. checked entire system for grounds, shorts, etc but everything checks ok. cant afford electrician or new dryer, help.
Groups: Expert
Sounds like a timer problem. During cool down, timer contacts BK to R open which turns off the heat circuit. May be contact shorting inside timer. If timer does not fix the problem, you may return it. Whirlpool 8566184 Timer - AppliancePartsPros.comEric
Dryer Repair
