olpdawg
#1 Posted : Monday, July 7, 2014 6:39:12 PM(UTC)
olpdawg
whirlpool dryer trips circuit breaker during the cool down cycle. checked entire system for grounds, shorts, etc but everything checks ok. cant afford electrician or new dryer, help.
fairbank56
#2 Posted : Tuesday, July 8, 2014 4:42:10 AM(UTC)
fairbank56
Groups: Expert
Sounds like a timer problem. During cool down, timer contacts BK to R open which turns off the heat circuit. May be contact shorting inside timer. If timer does not fix the problem, you may return it.
Whirlpool 8566184 Timer - AppliancePartsPros.com
Eric
