Hello I have a Maytag washer mav7600aww. The cloths come out wet at end of cycle. I have changed the belt and it worked for one day, cloths were dry at end of cycle. Then the following day cloths are wet again at end of cycle. I open the lid when in spin cycle, the drum spins slow. Please help ASAP. Thank u in advance. Greatly appreciate the recommendation
Spin problems on these Maytag models are usually fixed by this part here. Part number: AP4009132
It is a relatively easy repair but having a helper, well, helps.
I have taken apart the thrust bearing kit and noticed there was a lot of grease all over the thrust pully/cam and washers. When I rotated the pulley clockwise the agitator spins And when. Rotated counter clockwise the drum spins. Do you think the transmission is bad? I want to know if it's worth fixing. How much a transmission cost for mav7600aww washer. Thank you for everything
I would operate it with the front panel off and see what is happening. It may be that the transmission is bad in which case I would recommend a new machine rather than replacing the transmission on this model.
Is it normal to have a lot thick grease all over thrust pulley bearing
