ajjas01
#1 Posted : Tuesday, February 3, 2015 4:15:16 AM(UTC)
ajjas01
Hello
I have a Maytag washer mav7600aww. The cloths come out wet at end of cycle. I have changed the belt and it worked for one day, cloths were dry at end of cycle. Then the following day cloths are wet again at end of cycle. I open the lid when in spin cycle, the drum spins slow. Please help ASAP. Thank u in advance. Greatly appreciate the recommendation
sidfink43
#2 Posted : Tuesday, February 3, 2015 4:14:42 PM(UTC)
sidfink43
Spin problems on these Maytag models are usually fixed by this part here.
Part number: AP4009132
It is a relatively easy repair but having a helper, well, helps.
ajjas01
#3 Posted : Thursday, February 5, 2015 8:08:25 AM(UTC)
ajjas01
I have taken apart the thrust bearing kit and noticed there was a lot of grease all over the thrust pully/cam and washers. When I rotated the pulley clockwise the agitator spins And when. Rotated counter clockwise the drum spins. Do you think the transmission is bad? I want to know if it's worth fixing. How much a transmission cost for mav7600aww washer. Thank you for everything
sidfink43
#4 Posted : Thursday, February 5, 2015 8:12:01 AM(UTC)
sidfink43
I would operate it with the front panel off and see what is happening. It may be that the transmission is bad in which case I would recommend a new machine rather than replacing the transmission on this model.
ajjas01
#5 Posted : Thursday, February 5, 2015 8:16:24 AM(UTC)
ajjas01
ajjas01
#6 Posted : Thursday, February 5, 2015 12:10:40 PM(UTC)
ajjas01
Is it normal to have a lot thick grease all over thrust pulley bearing
sidfink43
#7 Posted : Thursday, February 5, 2015 12:51:14 PM(UTC)
sidfink43
No it should be clean.
