johnnybnice
#1 Posted : Wednesday, May 13, 2009 7:16:01 PM(UTC)
johnnybnice
I just replaced the belt and breaks on my washer and put everything back together, but now the water will not stop filling up? hmmmmm??!!
#2 Posted : Thursday, May 14, 2009 2:02:11 AM(UTC)
Please see this one that I just replied to
http://forum.appliancepartspros...repair/33490-dinger.html
johnnybnice
#3 Posted : Thursday, May 14, 2009 3:20:11 AM(UTC)
johnnybnice
the washer fills and the level now works, but now the washer will not agitate. the washer just sits there through the cycle, then when time is up it goes into spin cycle, so the tub does spin, but will not agitate, what could be wrong, could i have some wires hooked up wrong? there are two connectors, a red and a white one, could they be hooked up incorrectly?
#4 Posted : Thursday, May 14, 2009 4:17:13 AM(UTC)
A Model Number might help.
Also where are the two connectors?
Could be the level switch contacts which close to tell the machine that the unit is full of water and it should agitate are not closing.
johnnybnice
#5 Posted : Thursday, May 14, 2009 1:42:55 PM(UTC)
johnnybnice
the model number on this Amana is lwd70aw, thanks
#6 Posted : Friday, May 15, 2009 1:30:33 AM(UTC)
Cannot find a wiring diagram for this unit.
water level control (Dishwasher Repair)
by pfoxharp 12/29/2017 7:15:54 AM(UTC)
Water level control (Washer Repair)
by FLDAVE 12/8/2013 12:43:39 PM(UTC)
water level control kaput? Kenmore portable washer (Washer Repair)
by damenefee 10/25/2011 10:18:54 AM(UTC)
Installing Whirlpool water level control (Washer Repair)
by nnieser 3/27/2011 6:28:56 AM(UTC)
Water Level Control (Washer Repair)
by Hunter30 9/14/2010 11:16:12 AM(UTC)
timer control or water level control? (Washer Repair)
by Elehairyjob5 2/18/2010 6:13:30 AM(UTC)
which part do I need for water level control so washer does not over fill? (Washer Repair)
by Paul Bailey 8/13/2009 2:10:21 PM(UTC)
Water Level Control does not work (Washer Repair)
by darkhorse 8/30/2008 4:21:25 PM(UTC)
