Paul Solarz
#1 Posted : Sunday, December 16, 2007 9:24:55 AM(UTC)
Paul Solarz
Dryer heats up for a few minutes and then starts to cool down. Will not heat up after that. I have cleaned the duct work and internal parts. I am guessing the thermostat is bad, but notice there are two on the parts list for Whirlpool. Do I replace both ? Also, on the site the part does not look the same as it does on my dryer....
Any help would be great. I'm sure I can change these myself.
Paul
kawfeeman
#2 Posted : Sunday, December 16, 2007 9:30:43 AM(UTC)
kawfeeman
if the hot surface ignitor still continues to try to ignite the gas, and the gas never comes ( which never comes out ) then, more than likely your problem is with the coils on your gas valve in the dryer ...
Paul Solarz
#3 Posted : Sunday, December 16, 2007 10:21:46 AM(UTC)
Paul Solarz
Thanks Jim, so what do you think, call a repair tech ?
kawfeeman
#4 Posted : Sunday, December 16, 2007 1:25:37 PM(UTC)
kawfeeman
well it depends on how handy you are ? if you see the glow of the ignitor and the gas never comes on , replacing the coils on top of the gas valve is really pretty easy... if you are electrically oriented then diagnosing a thermal cut out / thermostat problem is not that bad either .. set the dryer for low temp for 60 minutes and after 20 minutes pull the toe kick / kick plate off and see if you see the ignitor ( glo-bar ) cycle on / off ?
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
by Guest 4/20/2024 7:14:50 AM(UTC)
Whirlpool Gas Dryer motor overheating - shuts-off (Dryer Repair)
by animateme 9/19/2019 11:59:22 AM(UTC)
Whirlpool gas dryer (Dryer Repair)
by JoAnninWV 5/7/2017 8:06:39 PM(UTC)
Whirlpool Gas Dryer heating intermittently, timer not working (Dryer Repair)
by christyhecht 5/2/2017 10:50:15 AM(UTC)
Whirlpool Gas Dryer screaching noise at first, then stops mid cycle (Dryer Repair)
by SRALPH 12/14/2016 11:40:34 AM(UTC)
Whirlpool Gas Dryer Takes Too Long (Dryer Repair)
by bijalshah01 9/28/2016 5:28:12 PM(UTC)
Whirlpool Gas Dryer Heating Problem (Dryer Repair)
by rinkugaya 9/24/2016 3:17:35 PM(UTC)
Whirlpool gas dryer heating issues/gas smell (Dryer Repair)
by Houseforsaken 8/8/2016 1:24:58 PM(UTC)
Whirlpool gas dryer no heat (Dryer Repair)
by alabamainnevada@yahoo.com 6/23/2015 5:54:15 PM(UTC)
Need Wiring Diagram for Whirlpool Gas Dryer (Dryer Repair)
by ToddErickson 2/2/2015 4:11:08 PM(UTC)
Whirlpool gas dryer only heats for the first 5-10 minutes of cycle (Dryer Repair)
by Peter Wood 9/18/2014 7:28:53 PM(UTC)
Whirlpool Gas Dryer LP to NG (Dryer Repair)
by kyle_8888 4/10/2014 9:49:37 AM(UTC)
Whirlpool Gas Dryer - heat won't stay on (Dryer Repair)
by tubegeek 3/11/2014 1:10:32 PM(UTC)
by jeswon 12/16/2013 6:55:50 AM(UTC)
by miller42 9/4/2013 6:43:14 AM(UTC)
