bigbuckkie
#1 Posted : Friday, December 19, 2014 4:28:48 PM(UTC)
bigbuckkie
i got this unit from a friend, and has been in storage. i install unit and only the dryer works, checked connection from washer to dryer and is connected properly, what should be my next step in trouble shooting this unit, i have tester to test electrical
sidfink43
#2 Posted : Monday, December 22, 2014 6:43:58 AM(UTC)
sidfink43
Use your tester to check and see that 110-120 v is getting to the timer. Then check the water level switch to make sure it is not stuck and finally check the current to the water valves to see if they are getting power when the timer calls for water. And of course check to make sure the water is on and unimpeded to the unit.
GE Cafe dishwasher will not start (Dishwasher Repair)
by Guest 5/18/2023 11:11:14 PM(UTC)
Samsung dishwasher will not start wash cycle (Dishwasher Repair)
by relentless85 8/12/2016 5:57:33 PM(UTC)
Dishwasher Will not start (Dishwasher Repair)
by BajaScout 10/31/2015 12:54:52 PM(UTC)
kitchen aide dishwasher will not start (Dishwasher Repair)
by Edwin L Davis 4/26/2015 6:02:45 PM(UTC)
Maytag Centennial washer will not start (Washer Repair)
by TurnpikeJ09 3/8/2015 7:44:44 PM(UTC)
washer will not start filling/timer suspected (Washer Repair)
by rossgray 3/2/2015 10:32:38 AM(UTC)
Kitchenaid dishwasher will not start and makes humming noise (Dishwasher Repair)
by jbritton@evisionsys.com 9/28/2014 9:08:26 AM(UTC)
Frigidaire Affinity Washer Will Not Start or Display Diagnostic Codes (Washer Repair)
by pwmin 8/5/2014 7:40:09 PM(UTC)
Neptune washer will not start (Washer Repair)
by Wilsonwelch 5/2/2014 10:17:36 AM(UTC)
Maytag dishwasher will not start (Dishwasher Repair)
by timwhitten 3/24/2014 2:15:09 PM(UTC)
washer will not start if medium load selected (Washer Repair)
by Brucek 6/8/2013 11:35:04 AM(UTC)
Diswasher will not start cycle (Dishwasher Repair)
by gcooker 4/28/2013 8:51:03 AM(UTC)
GE front load washer will not start (Washer Repair)
by LisaHall 1/23/2013 2:53:39 PM(UTC)
GE Washer will not start (Washer Repair)
by neco187 1/12/2013 6:40:54 PM(UTC)
Dishwasher will not start (Dishwasher Repair)
by genegilbert 11/18/2012 6:45:22 AM(UTC)
