Rockytech
#1 Posted : Sunday, December 14, 2014 8:51:36 AM(UTC)
Rockytech
After a home power failure, the display faded, the went black. The oven still works normally, but no display.:confused:
#2 Posted : Monday, December 15, 2014 6:35:46 AM(UTC)
Parts for Whirlpool RBD245PDQ14 Oven - AppliancePartsPros.com
Sounds like a control board problem (item 3 in section 06).
The fading and then going black is often a bad capacitor on the control board.
Rockytech
#3 Posted : Wednesday, December 17, 2014 5:02:30 PM(UTC)
Rockytech
Originally Posted by: denman Go to Quoted Post
denman,
I can actually see the display when the room is very dark. You mentioned a possible bad capacitor, is it an smt or through hole type?
Rockytech
#4 Posted : Thursday, December 18, 2014 12:38:35 AM(UTC)
I am not sure what you mean by " is it an smt or through hole type?"
The problem capacitors are the electrolytic capacitors (black cans if the picture of the control board is correct).
Below is info on this type of problem.
Note: that there is no guarantee that this is the cause.
Manufacturers do not publish board schematics so there is not way to check.
Read more: http://forum.appliancepartspros...splay.html#ixzz3MExj7q00
http://forum.appliancepartspros.com
http://forum.appliancepartspros...ml?highlight=dim+display
http://forum.appliancepartspros...ermador-double-oven.html
Rockytech
#5 Posted : Monday, December 22, 2014 2:12:29 PM(UTC)
Rockytech
Hi Denman,
My latest scenario is that I heard the oven beep a few times and now not even the oven heats up anymore. I believe there is a transformer connected to the control board. What is the output of the transformer? In an earlier response, you wondered about "smt" and "through hole" caps. SMT is "surface mount technology" where parts are soldered on one side of the circuit board and "through hole" would be a resister or cap that has leads pushed through the circuit board solder holes
Rockytech
#6 Posted : Monday, December 22, 2014 2:13:00 PM(UTC)
Rockytech
Hi Denman,
Rockytech
#7 Posted : Monday, December 22, 2014 2:24:13 PM(UTC)
Rockytech
Hi Denman,
#8 Posted : Tuesday, December 23, 2014 4:50:15 AM(UTC)
Looking at the views in the parts, it is 24 volts.
The capacitors are cans so it will be through hole.
see the attachment for the tech sheet.
Just in case you do not have it.
File Attachment(s):
RBD245.pdf (505kb) downloaded 3 time(s).
Rockytech
#9 Posted : Saturday, December 27, 2014 8:27:02 AM(UTC)
Rockytech
denman,
I went through the power side of the board, both AC on each side of the board including the working thermal fuse. The power to the transformer from the board and the feed back of 24V to the board are fine. I guess for sure this means the controller board needs replacement. Question, on the board there are wires going through black plastic housings, but are difficult to remove. Also, there are 4 red wires with quick disconnect terminals 2 of which have 120. Do you just pull them off or does the black plastic part just pull off with all wires intact? I have a pic of the back of the board, but don't know how to attach it to this message.
Phil
#10 Posted : Saturday, December 27, 2014 8:54:14 AM(UTC)
Sorry but I do not know the answer to this question.
