nugentc
#1 Posted : Sunday, December 14, 2014 10:25:17 AM(UTC)
nugentc
The lock light is flashing on the dishwasher and other keys don't work. I've tried lots of suggested fixes to get it to reset--holding down the heated dry/lock button for 10+ seconds, pressing it many times in rapid succession, holding down all keys in succession from left to right, and disconnecting power. I've also tried taking apart the inner panel and disconnecting/reconnecting all connectors to the mother board. Nothing helps. Once in a while I can get the Cancel button to come on and blink with the Lock on light, but not consistently. Once the Cancel button worked by itself and it ran a drain cycle (button is Cancel/Drain together). Any help would be appreciated.
Thanks!
#2 Posted : Monday, December 15, 2014 12:46:08 AM(UTC)
The given model number is incomplete.
Kenmore numbers are usually 3 digits, a period and then an additional 8 digits.
Could be either the control board or the control panel (keypad).
The usual way to trouble shoot this is to measure the key outputs with a meter but you need the tech sheet to get the outputs.
If the keypad checks OK then replace the control board.
Still a bit of a gamble but the odds are better.
nugentc
#3 Posted : Saturday, December 20, 2014 5:09:55 AM(UTC)
nugentc
Thanks for the help, denman. 665 are the first three digits. Unfortunately the keypad only comes in black and our dishwasher is white. It's expensive for a nonmatching part, so we might be looking at buying something used on craigslist to get us a couple more years until a kitchen renovation.
#4 Posted : Saturday, December 20, 2014 7:05:05 AM(UTC)
See the attachment for the ttech sheet.
Unforetunately ot does not give the control panel pin-outs.
File Attachment(s):
15772990.pdf (472kb) downloaded 3 time(s).
