belair1956
#1 Posted : Saturday, December 6, 2014 10:15:24 AM(UTC)
belair1956
Our water dispenser has a slow leak. It drips from below the bottom trim piece. It has recently begun to form condensation spots on the door panel.
Photo attached. Thoughts?
Thanks!
belair1956 attached the following image(s):
BoardRestored
#2 Posted : Tuesday, December 9, 2014 9:41:00 AM(UTC)
BoardRestored
Is it dripping from the water line above the tray that's shown in the picture?
If yes, it's going to need a new water valve (behind fridge).
If no, it sounds as if the water line inside the door has a leak. That would be bad news.
Let us know.
belair1956
#3 Posted : Tuesday, December 9, 2014 10:57:31 AM(UTC)
belair1956
Let us know.
The water is coming out from behind the bottom of the black panel. It now looks like it's the valve itself, photo attached. The bottom drip pan was full and overflowing. Easy to replace? Thanks for the reply!
BoardRestored
#4 Posted : Tuesday, December 9, 2014 12:48:52 PM(UTC)
BoardRestored
To me it looks like the line in the door is busted. Perhaps it froze in the line at some point causing the line to break.
This isn't for your exact model or even your brand for that matter, but this is the rough idea of what's involved with replacing that line.
Waterline replacement on a WP fridge
belair1956
#5 Posted : Tuesday, December 9, 2014 1:01:02 PM(UTC)
belair1956
Thanks. I think I'll replace this part first:
GE WR57X10032 Water Inlet Valve - AppliancePartsPros.com
Looks easy! I'll let you know if it stops the leak.
Jerry
BoardRestored
#6 Posted : Tuesday, December 9, 2014 1:16:05 PM(UTC)
BoardRestored
Yep, you and I think alike. I'd start there and keep my fingers crossed.
I'd be curious to know the outcome.
Good luck!
GE Refrig water dispenser leaking (Refrigerator & Freezer Repair)
by tvlensman 1/14/2013 1:23:13 PM(UTC)
Front filter water dispenser leaking (Refrigerator & Freezer Repair)
by trogers2000 11/23/2012 10:42:13 AM(UTC)
Water dispenser leaking on Kenmore Coldspot side-by-side (Refrigerator & Freezer Repair)
by DBSmith 12/26/2011 4:26:26 PM(UTC)
water line to water dispenser leaking at pump (Refrigerator & Freezer Repair)
by rfosterk 7/5/2011 12:46:58 PM(UTC)
Water Dispenser leaking (Refrigerator & Freezer Repair)
by rmulero 1/3/2011 9:05:46 AM(UTC)
GE fridge PS123SGMD water dispenser leaking (Refrigerator & Freezer Repair)
by slider14 7/12/2010 4:07:52 AM(UTC)
water dispenser leaking when not in use (Refrigerator & Freezer Repair)
by filler 11/15/2009 4:31:19 PM(UTC)
Whirlpool Fridge Water Dispenser Leaking (Refrigerator & Freezer Repair)
by Oshay1 4/9/2009 9:00:26 AM(UTC)
kenmore refrigerator water dispenser leaking (Refrigerator & Freezer Repair)
by jdil923 9/16/2008 5:16:57 PM(UTC)
Water dispenser leaking? (Refrigerator & Freezer Repair)
by 02Lightning 3/21/2008 6:59:09 PM(UTC)
