mbe5003
#1 Posted : Sunday, November 30, 2014 1:49:35 PM(UTC)
mbe5003
Dryer stopped heating so I did the troubleshooting and everything checked out so it pointed to the control board. It had exactly 10 ohms in the heater circuit and it was within the range (12.something KOhms) for the thermal fuse/thermistor circuit. so at that point it said to replace the control electronics. I went to my parts store and they ordered me Part # W10405827 based on the parts diagram for my model, even though the model number on the board itself was W10317636. Well the board they ordered did the exact same thing when I installed it, machine turned on and ran fine but didn't heat. So I went back and they swapped it out for the one matching the board that I had (the ...636 number) and now the machine won't do anything, attached is a picture of the display when I plug it in. No buttons function at all, no beeping or anything. The only noticible difference between the original board and this one is that the original said REV B and this one says REV C after the part number.
UserPostedImage[/url]
Whats the next step??? I'm going to try going back to the parts store tomorrow with this board and see what they tell me.
#2 Posted : Sunday, November 30, 2014 2:57:16 PM(UTC)
I cannot say what is going on with the boards.
When it ran but did not heat did you check the power?
The board and motor use half the line (120 volts) but the heater requires the full 240 volts (L1 to L2)
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
mbe5003
#3 Posted : Monday, December 1, 2014 4:55:25 PM(UTC)
mbe5003
Well I got the original board back and after some farther investigation it was just a simple fix, I tested and had power at the outlet and tested the cord and had continuity, but when I tested for power at the drier one of the legs kept showing zero. It took some simple bending of the prongs on the plug to make sure they were making good contact and that was it.
Drier is working like normal again, thanks for the advice with the power and how only the drier needs one of the legs that really helped narrow down the problem.
#4 Posted : Tuesday, December 2, 2014 12:32:28 AM(UTC)
You are welcome.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
