The bottom warming drawer in our oven (Frigidaire GLGS389FQ) has gone flaky. I can turn it on, and sometimes it will heat up, sometimes not. When it is on, it will sometimes stay on, and sometimes turn itself off, even though the on light stays on, and this is regardless of what heat setting it is on.
What am I checking for this unit? Conductivity? Thermostat?
If you could link me the relevant diagrams and what checks I should run, I can take it apart and replace the components that out faulty.
Appreciate the help,
Lewis
You seem to be missing the last digit in the model number. Please check it.
On most units this often does not make a difference but on this one it looks like A, B or E ranges are wired differently. |
THIS FORUM IS DEAD!!!!!!! |
I found the missing letter on the side label in the oven. It wasn't on the order or manual. It is GLGS389FQA
Originally Posted by: denman  You seem to be missing the last digit in the model number. Please check it.
On most units this often does not make a difference but on this one it looks like A, B or E ranges are wired differently. I found the missing letter "A" at the end. Anyone have any ideas? Thanks, Lewis
