KWB
#1 Posted : Tuesday, May 12, 2009 11:53:32 AM(UTC)
KWB
I have a older Fridgidaire stove that has 2 of the eyes either completely off or on high - regardless of where the control knob is set. There is no low or medium temperature. I am not a technician but someone told me it was the thermostat/ control knob. Does anyone have any information or suggestions? Can this be repaired without alot of knowledge or expense?
applianceman
#2 Posted : Tuesday, May 12, 2009 1:39:45 PM(UTC)
applianceman
The problem is in the surface unit switch (control switch). You will have to know the model number to order the switch. One tip I will give you is that when you replace the switch; do not unhook any of the wires to the old switch until the new one is in place if possible. Then unhook the wires one at a time and place them on the appropriate terminal on the new switch because if you hook it up wrong you can ruin all of the switches on the range or worse! Also make sure you disconnect the power to the range before attempting this. Oh and be sure to read any instructions that come with the new switch. Hope this helps. Range Repair Guide
KWB
#3 Posted : Tuesday, May 12, 2009 1:54:22 PM(UTC)
KWB
This may sound dumb but where would I find the model no.??
applianceman
#4 Posted : Wednesday, May 13, 2009 5:35:50 AM(UTC)
applianceman
On most ranges it’s in the storage drawer but on some of the older Frigidaires ranges it was under one of the surface units, if not it may be in the oven door.
Hot and cold swap (Washer Repair)
by frobnoid 10/7/2014 4:31:02 AM(UTC)
Hot And Cold Ok But Warm/warm And Cold/cold/ Not Working (Washer Repair)
by maxy212 9/25/2013 5:24:00 PM(UTC)
Warm is hot and cold just a trickle (Washer Repair)
by rgkallen 7/1/2010 12:50:47 PM(UTC)
hot and cold water feed (Washer Repair)
by ggangel 7/24/2008 6:02:55 PM(UTC)
