With water temp dial set to warm water is hot. When set to cold there is only a trickle.
Is it the cold water valve? If so what is part no. and how does one replace it.
Thanks.
Check to see that the cold water inlet is not clogged (it has a wire mesh filter) and that power is getting to the valve when it is supposed to. If those check out, try replacing the valve, this part here. Part number: AP3094541
