rgkallen
#1 Posted : Thursday, July 1, 2010 12:50:47 PM(UTC)
rgkallen
With water temp dial set to warm water is hot. When set to cold there is only a trickle.
Is it the cold water valve? If so what is part no. and how does one replace it.
Thanks.
sidfink43
#2 Posted : Saturday, July 3, 2010 4:22:46 PM(UTC)
sidfink43
Check to see that the cold water inlet is not clogged (it has a wire mesh filter) and that power is getting to the valve when it is supposed to.
If those check out, try replacing the valve, this part here.
Part number: AP3094541
This site will show you how to open your machine to get to it.
SublimeMasterJW's Appliance Advice: Kenmore top loader blues
