Ross985
#1 Posted : Friday, November 14, 2014 1:19:06 PM(UTC)
Ross985
I just replaced the heating element and dryer still not heating...Could it be one or both of the thermostats? I have a multimeter, but don't know what the numbers should be when testing.
#2 Posted : Saturday, November 15, 2014 1:01:58 AM(UTC)
A model number may help others help you.
Find your model number - AppliancePartsPros.com
On older units it could be a number of things:
Thermal cut-off
Hi-limit thermostat
Cycling thermostat
Timer contacts
Motors heater centrifugal switch
Heating element which you have already replaced. Note that it is not unheard of to receive a bad replacement part.
But first I would check the power.
The motor and drum light work off of half the line (120 volts) but the heater requires both sides of the line (240 volts).
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
whirlpool Heating element (Dishwasher Repair)
by tengen 6/7/2015 8:39:30 AM(UTC)
Whirlpool Heating Element Not Working (Dishwasher Repair)
by muegge99 3/27/2013 4:27:13 PM(UTC)
by sfuller 12/4/2010 10:11:17 AM(UTC)
Whirlpool Heating Element Problem (Dishwasher Repair)
by dwtiger 9/8/2010 5:06:44 AM(UTC)
Wiring a whirlpool heating element part #37001139 (Dryer Repair)
by necie7006 1/8/2009 12:23:03 PM(UTC)
whirlpool heating elements (Dryer Repair)
by grosen1107 1/24/2008 12:25:07 PM(UTC)
Replacing whirlpool heating element (Dryer Repair)
by jp882 1/12/2008 2:31:07 PM(UTC)
