mariablazek
#1 Posted : Sunday, September 28, 2014 4:43:00 PM(UTC)
mariablazek
Hello, We really need help. Our ovens were not working, we tested the temperature sensors and they were fine, we just replaced the control board and now we have a F1-1, We do not know what else to do, could it be the top oven baking element? We tried the top oven once after replacing the control board, it worked fine, but it was not as hot as the bottom oven, and after food was done the light build went out and the F1-1 appeared again. We love our double oven and dont want to get rid of it, please help us....
mariablazek
#2 Posted : Sunday, September 28, 2014 5:17:34 PM(UTC)
mariablazek
also, what and where is the membrane switch? please read last line "correction"....
F1-1: Temperature runaway. Membrane switch shorted. Alarm is continuous, if cancel key is pressed alarm will stop, if fault still present alarm will repeat. If membrane switch is disconnected the alarm will only sound for 30 seconds and stop.
Correction: Test membrane switch and oven sensor, if OK, replace control.
F1-1 F2-3 and F1-2Errors (Oven Repair (including Ranges and Cooktops))
by silentdub 2/15/2022 6:01:40 PM(UTC)
Maytag Gemini F1-1 Code (Oven Repair (including Ranges and Cooktops))
by vcolella 5/30/2014 10:04:20 AM(UTC)
f1-1 again..... arrrgghhh gemini double oven (Oven Repair (including Ranges and Cooktops))
by The Country Toad 10/23/2013 2:18:18 PM(UTC)
Oven getting F1-1 error - need to make sure I get proper contol panel (Oven Repair (including Ranges and Cooktops))
by beemie96 9/1/2011 9:59:01 AM(UTC)
Error codes F1-1 and F3-1 (Oven Repair (including Ranges and Cooktops))
by dawirick 2/28/2009 1:34:50 PM(UTC)
F1-1, F1-2, F1-h (Oven Repair (including Ranges and Cooktops))
by beachrog 9/23/2008 4:49:42 AM(UTC)
maytag gemini F1-1,F3-1 codes (Oven Repair (including Ranges and Cooktops))
by ewenjo 8/15/2007 3:13:16 PM(UTC)
