brygar
#1 Posted : Wednesday, September 10, 2014 7:08:45 PM(UTC)
brygar
The dryer turns on, but when start button is pushed a "click" is heard and nothing happens. During diagnostics the error code "3E" comes up. The thermal fuse has continuity.
#2 Posted : Saturday, September 13, 2014 12:28:35 AM(UTC)
Parts for Maytag MED9700SB0 Dryer - AppliancePartsPros.com
See the attachment for a tech sheet.
Have you tried unplugging the unit for several minutes to see if it will reset?
Run the tests in the tech sheet.
Unplug the unit and measure from P1-4 to P1-3 at the control boar with a meter.
You should see about 1 to 2 ohms (the motor windings, thermal fuse and belt switch circuit).
In the tech sheet they say up to 6 ohms this seems high to me as even two motor windings at 4 ohms gives a 2 ohm measurement as they are in parallel.
Be sure to use the most sensitive meter scale and short the meter leads together before starting so you can see it there is a zero offset in the meter.
If the above is OK measure from P1-3 to Neutral, should be 0 ohms.
If both are OK then odds are that the control board is shot.
File Attachment(s):
MED9700.pdf (343kb) downloaded 5 time(s).
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
