Washer seems to run then won't spin. Used to be able to coax it to spin on "Drain and Spin" cycle. Now it won't spin at all. When it first started giving me trouble, it would start to spin and then stop. Now the lid lock light flashes most of the time. I am livid!!!!!!!!!!!!!!!!!!!!!!
Groups: Expert
Open the top panel and retrieve the tech sheet from inside the cabinet. Instructions for opening top below. Follow the directions on tech sheet to get into service mode to retrieve any error codes and post them here. I think you most likely either have something in the drain pump or the shift actuator is bad. Eric
