AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Frigidaire Affinity Washer Will Not Start or Display Diagnostic Codes
I tried using my washer tonight and the only thing any button will do is change the temperature. I cannot get it to start or enter diagnostic mode by pushing start and cancel at the same time for 5+ seconds. I've tried unplugging it for 10 minutes also and resetting to factory settings and no progress. The only thing different it will do is when I have it on Rinse & Spin, all the temperature lights will blink.
Now that I unplugged it overnight, it's working again. I had also been having issues of the temperature lights flashing while running. I thought it was because of having too much in the washer, but it will still do it when it's not full.
I got one load done and now it's doing the same thing again.
I am having the exact same problem been happening for a couple months off and on. Did you find a solution? I'll let you know if i figure it out also.
I haven't figured it out yet. If I want to use it, I have to unplug it for an hour between uses. Thanks, I'll post here if I figure it out. I'm guessing it's the control panel, but I don't know for sure.
Washer Repair
