pwmin
#1 Posted : Tuesday, August 5, 2014 7:40:09 PM(UTC)
pwmin
I tried using my washer tonight and the only thing any button will do is change the temperature. I cannot get it to start or enter diagnostic mode by pushing start and cancel at the same time for 5+ seconds. I've tried unplugging it for 10 minutes also and resetting to factory settings and no progress. The only thing different it will do is when I have it on Rinse & Spin, all the temperature lights will blink.
pwmin
#2 Posted : Wednesday, August 6, 2014 7:43:20 AM(UTC)
pwmin
Now that I unplugged it overnight, it's working again. I had also been having issues of the temperature lights flashing while running. I thought it was because of having too much in the washer, but it will still do it when it's not full.
pwmin
#3 Posted : Wednesday, August 6, 2014 8:40:59 AM(UTC)
pwmin
I got one load done and now it's doing the same thing again.
bxtr97
#4 Posted : Thursday, August 7, 2014 12:20:00 PM(UTC)
bxtr97
I am having the exact same problem been happening for a couple months off and on. Did you find a solution? I'll let you know if i figure it out also.
pwmin
#5 Posted : Friday, August 8, 2014 1:23:33 PM(UTC)
pwmin
I haven't figured it out yet. If I want to use it, I have to unplug it for an hour between uses. Thanks, I'll post here if I figure it out. I'm guessing it's the control panel, but I don't know for sure.
