2 Pages12>
gohuskers
#1 Posted : Sunday, July 27, 2014 5:17:12 PM(UTC)
gohuskers
I installed a new water control valve and icemaker and the icemaker appears to be cycling but no water. I checked the tubes and all seem to be free of ice and working. We gave it over a week now. The new icemaker model is RIM Hi-Start 201401. Suggestions appreciated.
bfridge
#2 Posted : Sunday, July 27, 2014 9:15:33 PM(UTC)
bfridge
When the ice maker goes through a cycle does the water valve activate?
#3 Posted : Monday, July 28, 2014 2:41:44 AM(UTC)
Do you have a red light optics in the freezer section?
gohuskers
#4 Posted : Monday, July 28, 2014 6:22:50 PM(UTC)
gohuskers
I'm not sure what that means but I don't see a red light.
gohuskers
#5 Posted : Monday, July 28, 2014 6:24:58 PM(UTC)
gohuskers
I don't know how to verify if that happens.
bfridge
#6 Posted : Monday, July 28, 2014 8:24:41 PM(UTC)
bfridge
When the ice maker goes through a complete cycle do you hear the water valve turn on? It should making a buzzing or humming sound.
#7 Posted : Tuesday, July 29, 2014 1:15:10 AM(UTC)
It's unfortunately common, but lots of times the voltage to the icemaker is missing due to a splice failure internal to the fridg. You will need a meter to check.
#8 Posted : Tuesday, July 29, 2014 1:17:34 AM(UTC)
Disregard that. Put 115 volts to the icemaker water valve in the back. If no water goes to the icemaker, you either have a frozen line or a bad valve.
gohuskers
#9 Posted : Tuesday, July 29, 2014 7:28:52 PM(UTC)
gohuskers
Thanks for the help. I will listen to the water valve during a cycle. Also, if you can tell me how to apply the 115v to the valve ...
Thanks again
gohuskers
#10 Posted : Tuesday, July 29, 2014 7:30:27 PM(UTC)
gohuskers
Also, is there a way to trigger a cycle?
2 Pages12>
