Kaymardixie
#1 Posted : Tuesday, July 15, 2014 3:58:29 PM(UTC)
Kaymardixie
My control lock light stays activated. I tried to unlock it by pressing the end cycle button 3 seconds as per the manual but it stays locked. I tried to unplug the machine but this also did not help. When I plugged it in the control lock light beeps and turns off and on. Any suggestions?
#2 Posted : Wednesday, July 16, 2014 4:04:18 AM(UTC)
Parts for GEW9250PQ - AppliancePartsPros.com
See if diagnostics will show anything.
If not.
Check that the end of Cycle key/button is working.
Could be it is closed all the time.
I do not think the above will show anything but it is worth a tyry.
Itsounds like the control board need replacing.
File Attachment(s):
GEW9250.pdf (342kb) downloaded 2 time(s).
Whirlpool Duet electric dryer model WED8300SW1 (Dryer Repair)
by Guest 9/9/2023 9:26:30 AM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
Whirlpool Duet electric dryer overheats despite replacing various parts (Dryer Repair)
by Manec 8/18/2016 6:49:44 PM(UTC)
Whirlpool Duet Electric Dryer Won't Do anything (Dryer Repair)
by mbe5003 11/30/2014 1:49:35 PM(UTC)
Whirlpool Duet electric dryer drum not turning (Washer Repair)
by drmjtn 11/2/2014 7:52:05 AM(UTC)
whirlpool duet electric dryer no heat (Dryer Repair)
by Reisingera03 2/6/2013 2:49:42 PM(UTC)
Whirlpool Duet Electric Dryer won't get hot (Dryer Repair)
by lisaal 10/30/2012 5:43:42 PM(UTC)
whirlpool duet electric dryer does not heat (Dryer Repair)
by alxholbrook 9/28/2012 6:21:38 AM(UTC)
Whirlpool Duet Electric Dryer (Dryer Repair)
by Sandi Van Camp 11/12/2011 7:48:08 PM(UTC)
Whirlpool Duet Electric Dryer does not turn on (Dryer Repair)
by vong 11/3/2011 5:30:28 PM(UTC)
Whirlpool Duet electric dryer wont start (Dryer Repair)
by miketieman 6/20/2011 8:40:50 AM(UTC)
whirlpool duet electric dryer works but no heat (Dryer Repair)
by sbfire370 4/13/2011 3:24:11 AM(UTC)
