Replaced the Overload Relay Kit, Repair Part Number 12002794. Refrigerator evaporator fan started running and and it felt like the fridge and Freezer was starting to cool, this lasted for about a half hour then it stopped working again. Any ideas on what the problem might be, or what I should check next to find the problem would be much appreciated.
Could be the unit just went into a defrost cycle. How long have you waited for it to come back on? Defrost usually takes about half an hour.
Also what is not working? The evaporator/freezer fan? The condenser/compressor fan? The compressor? Usually you can hear it but also should be able to feel it vibrating.
Note that when one of the above is on thay all should be on. |
THIS FORUM IS DEAD!!!!!!! |
