Lifterfe
#1 Posted : Saturday, April 23, 2011 4:10:10 PM(UTC)
Lifterfe
My display is going dim and I've read that the control panel needs to be replaced. I removed the side trim but can't seem to figure out how to get the trim off from around the touch panel/control panel. I pulled a little too hard and broke the plastic on the back side of the trim panel (the part that houses the touch panel) where it screws into the control panel. :eek: I know I can fix it if I can just get behind the panel.
I read this but it's not for my model:
https://secured.whirlpoo...4ddde3385256a7e00524e76/$FILE/8178007.pdf
Please help!
Lifterfe attached the following image(s):
mashmaster
#2 Posted : Saturday, July 12, 2014 8:54:49 AM(UTC)
mashmaster
I also can't remove the control panel portion. I have the side trim removed and the two screw holding the control panel section in place. There must be a trick to removing the top section.
#3 Posted : Saturday, July 12, 2014 10:13:35 AM(UTC)
Perhaps the following will help
http://appliancejunk.com...wnloads;sa=view;down=169
You will have to join the site and be logged in to be able to download the manual.
If your problem is a dim display the following has some info on this problem.
http://forum.appliancepartspros...wall-oven-display-2.html
http://forum.appliancepartspros...or-display-very-dim.html
mashmaster
#4 Posted : Saturday, July 12, 2014 6:14:55 PM(UTC)
mashmaster
Unfortunately, I have already read this manual. It doesn't seem to want to come off as described in the manual.
#5 Posted : Sunday, July 13, 2014 1:25:40 AM(UTC)
Try pushing it up to see if it will unclip.
Click on the picture below and a new page will open take a look at the Q&A
Part number: AP4365434
sramussen63
#6 Posted : Friday, October 10, 2014 5:45:08 AM(UTC)
sramussen63
Mashmaster - did you ever figure out how to get the trim pieces off? I'm in the same boat!
mashmaster
#7 Posted : Friday, October 10, 2014 9:13:56 AM(UTC)
mashmaster
Yes, I had to have a repair guy come out. The manual is incorrect which is frustrating. But you need to remove the trim, then the for screws that hold the oven flush to the cabinet. Slide the oven out maybe 2-3 inches. There are two screws on top of the control panel that hold it in place. After that is dissassembles easily.
sramussen63
#8 Posted : Friday, October 10, 2014 4:13:40 PM(UTC)
sramussen63
Mashmaster -- your commission on my savings will be in the mail shortly! I slid the oven out, undid the screws and voila! 35 minutes later, I have a working oven! Hip hip, horray! I even called a very nice local repairman who probably thought I was an idiot for not seeing the "screws that should be right there under the trim." He would have charged me $79 just to show up.
I am forever thankful! Have a wonderful weekend!
S
