Discuss
Thermador display is very dim
 in
The display on our oven is very dim, the only part of the display that shows anything is the clock,
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermador display is very dim
  #1 (permalink)
Old 09-13-2007, 07:27 AM
gtbdevs gtbdevs is offline
Junior Member
gtbdevs is on a distinguished road
Default Thermador display is very dim
Model Number: SCD302   Brand: Thermador   Age: 5 - 10 years
The display on our oven is very dim, the only part of the display that shows anything is the clock, the oven still seems to work, but some of the numbers on the keypad do not function.
I was going to order the control kit, which includes the display head, main power relay, and the harness keypad.
If I change all that, the problem should be fixed?
TIA
Related Models
Thermador SCD302T
Amana SCDE25J Ref - SXS/I&W
Amana SCDT20H Ref - SXS/I&W
Amana SCDT22H Ref - SXS/I&W
Amana SCDT25H Ref - SXS/I&W
Jenn-Air SCE30500B Range - S/c S/i Ele
Jenn-Air SCE30500W Range - S/c S/i Ele
Jenn-Air SCE30600B Range - S/c S/i Ele
Jenn-Air SCE30600BC Range - S/c S/i Ele
Jenn-Air SCE30600W Range - S/c S/i Ele
Jenn-Air SCE30600WC Range - S/c S/i Ele
Jenn-Air SCE4320B Range - S/c S/i Ele
Jenn-Air SCE4320W Range - S/c S/i Ele
Jenn-Air SCE4340B Range - S/c S/i Ele
Jenn-Air SCE4340B-C Range - S/c S/i Ele
Jenn-Air SCE4340W Range - S/c S/i Ele
Jenn-Air SCE4340W-C Range - S/c S/i Ele
Jenn-Air SCE70600B Range - S/c S/i Ele
Jenn-Air SCE70600W Range - S/c S/i Ele
Whirlpool SCF0710HQ00
Whirlpool SCF0710HQ01
Whirlpool SCF0710HW00
Whirlpool SCF0710HW01
Whirlpool SCF0710HW05
Whirlpool SCF0710KQ00
Whirlpool SCF0710KQ01
Whirlpool SCF0710KQ02 Chest Freezer
Whirlpool SCF0710KQ03 Chest Freezer
Whirlpool SCF0710KQ04 Chest Freezer
Whirlpool SCF1510HW00
Whirlpool SCF1510HW02
Whirlpool SCF1510HW05
Jenn-Air SCG20200A Range - S/c S/i Gas
Jenn-Air SCG20200B Range - S/c S/i Gas
Jenn-Air SCG20200W Range - S/c S/i Gas
Thermador SCM-1
Whirlpool SCS3004GN0
Whirlpool SCS3004GN1
Whirlpool SCS3004GS0
Whirlpool SCS3004GS1
Whirlpool SCS3004GS2
Whirlpool SCS3004GV1
Whirlpool SCS3004GV2
Whirlpool SCS3004GW0
Whirlpool SCS3004GW1
Whirlpool SCS3004GW2
Whirlpool SCS3004LW0
Whirlpool SCS3004LW01 30" Gas Cooktop
Whirlpool SCS3014GB0
Whirlpool SCS3014GB1
Whirlpool SCS3014GB2
Whirlpool SCS3014GB3
Whirlpool SCS3014GQ0
Whirlpool SCS3014GQ1
Whirlpool SCS3014GQ2
Whirlpool SCS3014GQ3
Whirlpool SCS3014GS0
Whirlpool SCS3014GS1
Whirlpool SCS3014GS2
Whirlpool SCS3014GS3
Whirlpool SCS3014GT1
Whirlpool SCS3014GT2
Whirlpool SCS3014GT3
Whirlpool SCS3014GZ0
Whirlpool SCS3014GZ1
Whirlpool SCS3014LB0
Whirlpool SCS3014LB01 30" Gas Cooktop
Whirlpool SCS3014LB02 30" Gas Cooktop
Whirlpool SCS3014LQ0
Whirlpool SCS3014LQ01 30" Gas Cooktop
Whirlpool SCS3014LQ02 30" Gas Cooktop
Whirlpool SCS3014LS0
Whirlpool SCS3014LS01 30" Gas Cooktop
Whirlpool SCS3014LS02 30" Gas Cooktop
Whirlpool SCS3014LT0
Whirlpool SCS3014LT01 30" Gas Cooktop
Whirlpool SCS3014LT02 30" Gas Cooktop
Whirlpool SCS3017RB00 30" Gas Cooktop
Whirlpool SCS3017RB01 30" Gas Cooktop
Whirlpool SCS3017RB02 30" Gas Cooktop
Whirlpool SCS3017RB03 30" Gas Cooktop
Whirlpool SCS3017RQ00 30" Gas Cooktop
Whirlpool SCS3017RQ01 30" Gas Cooktop
Whirlpool SCS3017RQ02 30" Gas Cooktop
Whirlpool SCS3017RQ03 30" Gas Cooktop
Whirlpool SCS3017RS00 30" Gas Cooktop
Whirlpool SCS3017RS01 30" Gas Cooktop
Whirlpool SCS3017RS02 30" Gas Cooktop
Whirlpool SCS3017RS03 30" Gas Cooktop
Whirlpool SCS3017RT00 30" Gas Cooktop
Whirlpool SCS3017RT01 30" Gas Cooktop
Whirlpool SCS3017RT02 30" Gas Cooktop
Whirlpool SCS3017RT03 30" Gas Cooktop
Whirlpool SCS3514GB1
Whirlpool SCS3614GB0
Whirlpool SCS3614GB1
Whirlpool SCS3614GB2
Whirlpool SCS3614GB3
Whirlpool SCS3614GQ0
Whirlpool SCS3614GQ1
Whirlpool SCS3614GQ2
Whirlpool SCS3614GQ3
Whirlpool SCS3614GS0
Whirlpool SCS3614GS1
Whirlpool SCS3614GS2
Whirlpool SCS3614GS3
Whirlpool SCS3614GT1
Whirlpool SCS3614GT2
Whirlpool SCS3614GT3
Whirlpool SCS3614GZ0
Whirlpool SCS3614GZ1
Whirlpool SCS3614LB0
Whirlpool SCS3614LB01 36" Gas Cooktop
Whirlpool SCS3614LB02 36" Gas Cooktop
Whirlpool SCS3614LQ0
Whirlpool SCS3614LQ01 36" Gas Cooktop
Whirlpool SCS3614LQ02 36" Gas Cooktop
Whirlpool SCS3614LS0
Whirlpool SCS3614LS01 36" Gas Cooktop
Whirlpool SCS3614LS02 36" Gas Cooktop
  #2 (permalink)
Old 09-15-2007, 11:39 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Hi gtbdevs
Yes, you need to replace the control kit. part number AP3382408
Be very careful removing the control panel. It is very heavy and if it falls down, the plug for the control panel circuit board could break off.
- Here is the break down diagrams for the Thermador double oven Model SCD302T
Good luck.
__________________
  #3 (permalink)
Old 09-16-2007, 02:07 PM
Junior Member
Default
Thanks, I did order those parts, and did the replace, all is working A.OK.
Glen
  #4 (permalink)
Old 09-16-2007, 03:51 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Good job!
__________________
  #5 (permalink)
Old 09-24-2007, 03:54 PM
leff leff is offline
Junior Member
leff is on a distinguished road
Default Thermador convections oven won't heat after a self clean
I fixed the dim panel problem with that replacement kit, and all was well for a couple months. Then, since a self clean, the upper oven won't heat at all. The display panel seems good, the exhaust fan works well. The lower oven is fine.
Did I damage the new control board, or is there a fried thermostat somewhere?
  #6 (permalink)
Old 09-29-2007, 08:06 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello Jeff,
It suppose to be a resettable hi limit thermostat which prevents the oven from overheating. It should be on top of the upper oven, on the right side of the door latch assembly. To reset it you have to push the red button in the middle of the thermostat.
- You can view the picture of the thermostat by clicking the part number AP2832064
Good luck.
__________________
  #7 (permalink)
Old 09-30-2007, 07:53 AM
Junior Member
Wink Gene you are the man
That reset button was the answer. Thanks! Now how about my Thermador cooktop -- I posted this in another thread:
Every day, the first time you try to use the range (six star burners, two are xlo) all six igniters click perfectly, but there is NO gas flow to any burner. Sometimes for a few minutes of clicking.
Finally, the gas starts to flow to all "on" burners. Then, we are good for the rest of the day--turn the knob, 1 or two clicks and gas flows and lights perfectly.
What to do???????
  #8 (permalink)
Old 10-01-2007, 01:03 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Jeff
Most likely the problem with your stove is a bad gas pressure regulator.
Post the complete model number and I might be able to give you more specific information.
__________________
  #9 (permalink)
Old 10-01-2007, 05:53 AM
Junior Member
Wink Thanks Again Gene
The cooktop is Thermador PCS366US, six star burners total, two are XLO, natural gas with a regulator mounted in the kitchen cabinet under the unit.
  #10 (permalink)
Old 10-30-2007, 04:51 PM
rcauthon rcauthon is offline
Junior Member
rcauthon is on a distinguished road
Default Me too, now
I am having a similar issue.
It started out with a bad lamp transformer. None of the oven lamps lit. I replaced the transformer, then only the lower oven would work.
I then replaced the main power board only. The panel was dim for the top oven and fine for the lower. I assumed the resistor included on the new board caused this. As the oven was used, the panel got dimmer to the point of being unreadable. The lamps don't work again now either.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador Cooktop Sparking Matt Schauer Oven Repair (including Ranges and Cooktops) 16 06-30-2009 09:01 PM
Dead Display d-man Oven Repair (including Ranges and Cooktops) 0 09-12-2007 05:46 PM
Thermador Free Standing Range SpaceAce Oven Repair (including Ranges and Cooktops) 1 08-14-2007 01:28 AM
Doesn't Run, No Display. Singer Dishwasher Repair 4 08-13-2007 01:27 PM
Only 8's showing on the erc display BruceL Oven Repair (including Ranges and Cooktops) 1 07-22-2007 11:20 PM
