Thanks, I also checked the parts list for the gear case for my washer and saw that it was Loctite 515. I couldn't get it locally so I ordered it, making sure I got the same size referenced, .20 FL OZ (6 mL), because this was cheaper than larger quantities. Now that I have it here in front of me I don't see how it's going to be enough to cover the case and cover like done in the following video:
https://www.youtube.com/watch?v=...=player_detailpage#t=466Does this guy use more than necessary, or does the sealer in this little bottle spread out more than I can imagine?
If it's not going to be enough, I'm tempted to go buy a bigger bottle of this
Permatex Anaerobic Gasket Maker (1.69 oz) Part No. 51813, which I can get locally at auto parts stores.
Regarding the syl-glyde on the brake drum, I may try that if I can't get the tub out. My local auto parts store has that stuff too (American Grease Stick Co. LUBRICANT SIL-GLYDE).
As far as getting the tub out, it feels impossible but I've read it just needs a lot of force and/or time and patience to get it out. One person said they poured boiling water in the whole drive tube assembly to get it to loosen, with the theory that it was gunked up with soap, and that warm water would dissolve that. It worked for them but I wondered if that was unwise considering boiling water might remove grease/oil that needed to be in there. Any thoughts on that idea?
Regarding your idea of tapping on the drive block with a large drift pin and hammer while two people lift on the tub, I have a question on that. I have never used a drift pin, but I see some listed here:
Klein Tools - Barrel-Type Drift Pins from Seton.com, Stock items ship TODAY, Custom ships FAST!![UserPostedImage](http://www.seton.com/media/catalog/product/Klein-Tools--BarrelType-Drift-Pins-21P-lg.jpg)
Do you mean like that? And if so I imagine I would drop it vertically inside the drive block until it stopped and then hammer on the top of the pin, but there is another narrower diameter tube inside/below my drive block, so I don't see how I could do that. What do you mean or what am I missing?
Here is the top part of my drive assembly:
![UserPostedImage](https://lh3.googleusercontent.com/-34RCpsxNLh4/U80fSg2IJII/AAAAAAAASe4/ykhSiWDCa5o/w640-h480-no/20140721_095538.jpg)
![UserPostedImage](https://lh4.googleusercontent.com/-RnDfU_763C4/U80fcBDd_yI/AAAAAAAASfA/VUHPwMlREAE/w480-h640-no/20140721_095829.jpg)
FWIW, while it's hard to tell in the pictures, the two tabs from the spin tube both seem to be intact when viewing it in person.
One other question. I read somewhere else that you shouldn't remove the tub while the transmission shaft is not in place (like in my current situation) because the "turbine oil" could get out. Did I remember that right or does that make sense?
In the mean time I am going to replace the spin gear and pinion which I am picking up from a store locally.
Again, thanks for all your help. Do you work for Appliance Parts Pros or do you do this in your free time?
