Discuss
Washer won't spin, It's not the clutch, brake, or lid switch.
 in
Washer Repair
Hello, I have a Kenmore model 110 that intermittently will not spin. It spins when draining but stops spinning prior
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer won't spin, It's not the clutch, brake, or lid switch.
  #1 (permalink)
Old 02-26-2013, 01:13 PM
Junior Member
ddeily is on a distinguished road
Default Washer won't spin, It's not the clutch, brake, or lid switch.
Model Number: 110   Brand: Kenmore   Age: More than 10 years
Hello,
I have a Kenmore model 110 that intermittently will not spin. It spins when draining but stops spinning prior to rinse. If I lift the lid and close it, it will start to spin again. It will also start to spin if I turn the machine off (push the timer button in) and restart (pull the timer button out). I have replaced the clutch and checked the brake and motor coupling and they are both good. I have also bypassed the lid switch and that does not help. I am thinking that it's the timer. Any advice? Also, how do you tell which timer is used for this machine, the web site lists several timers.
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 02-26-2013, 01:36 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
We need the complete model number. The 110 just means it's made by Whirlpool. When it stops spinning when it shouldn't, is the motor still running? Humming? All quiet?
Eric
  #3 (permalink)
Old 02-26-2013, 03:00 PM
Junior Member
Default
Quote:
Eric
The complete model number is 110 26812690. The motor sounds like its running when it's not spinning. As I mentioned, I've replaced the clutch.
  #4 (permalink)
Old 02-26-2013, 03:52 PM
Expert
APP Volunteer
Default
The timer you asked about is this one. The normal chain of events is after agitation it should start draining without spinning. After a minute or two of draining, the motor should pause for a few seconds and then start again and it should start spinning while continuing to drain. Does it stop spinning in the middle of the normal spin period or does it just not start spinning when it should? Either way, you need to remove the cabinet and jump out the lid switch so you can observe the clutch during operation. When it is supposed to be spinning but isn't, and the motor is running, check the clutch hub. If it's spinning and the tub isn't, then either the clutch is slipping, there's a problem with the basket drive or the drive block is slipping. If the hub isn't spinning and your sure the motor is running and the motor coupler is good, then the gearcase is bad.
Eric
  #5 (permalink)
Old 02-26-2013, 04:05 PM
Junior Member
Default
Eric
Thanks Eric, I'll check it out.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Transmission, brake clutch, or bearing??? jsspruill Washer Repair 0 01-12-2013 06:05 PM
Washer clutch? brake? transmission? help please. mcompton1973 Washer Repair 1 01-10-2012 05:23 PM
Sympton of bad brake clutch chuckers Washer Repair 0 09-21-2011 12:51 PM
Whirlpool brake or clutch issue mtreu Washer Repair 18 10-08-2010 01:53 AM
Clutch/Brake band replacement bigtandt Washer Repair 2 02-12-2010 08:18 AM
