kluever
#1 Posted : Saturday, July 5, 2014 4:50:26 AM(UTC)
kluever
I have a Maytag Double Oven with 2 issues. The bottom oven won't heat past 200* and the display panel has gotten so dim you can't see any numbers on it. We had the panel replaced a few years ago and it worked for a while, then started dimming again. Any ideas for either problem?
#2 Posted : Monday, July 7, 2014 3:28:59 AM(UTC)
Parts for Maytag MEW6630BAB Wall Oven - AppliancePartsPros.com
On the heating problem.
Does the unit stay in preheat?
If not (shows it is ready) it could be an oven sensor problem.
If it stays in preheat then it could be a bad element (most units switch between the bake and broil elements in preheat and bake modes).
Check them with a meter.
Be sure to unplug the stove when working on it. In most units one side of the elements always have power.
On the dim display.
This is a common problem.
There are electrolytic capacitors on the control board and they fail over time.
Often replacing them will fix the board.
Maytag Double OVen Model MGR6875ADW- Igniter wont stop ticking (Oven Repair (including Ranges and Cooktops))
by gnieciag 10/15/2023 1:53:42 PM(UTC)
Maytag Double Oven 750 Series Broil Code (Oven Repair (including Ranges and Cooktops))
by thomas66 5/14/2011 3:27:57 PM(UTC)
Maytag Double Oven door won't open (lock) (Oven Repair (including Ranges and Cooktops))
by tincup731 3/13/2011 5:29:06 AM(UTC)
Maytag double oven range (Oven Repair (including Ranges and Cooktops))
by Molly 27 2/22/2011 3:45:19 PM(UTC)
Maytag Double Oven Controller Failure (Oven Repair (including Ranges and Cooktops))
by ramblinche81 12/31/2009 9:43:13 AM(UTC)
Maytag Double oven burner not working on bottom (Oven Repair (including Ranges and Cooktops))
by mirekjanowiak 12/15/2009 12:37:54 PM(UTC)
Maytag double oven WIRE BURNING OUT (Oven Repair (including Ranges and Cooktops))
by rsabbag 12/3/2009 10:53:22 AM(UTC)
Maytag Double Oven Not Heating (Oven Repair (including Ranges and Cooktops))
by stevevidmar 5/27/2009 9:25:16 AM(UTC)
Dim Lights in controls of Maytag double oven range (Oven Repair (including Ranges and Cooktops))
by cityfolks 12/21/2008 4:11:30 PM(UTC)
