Have a maytag double oven. trouble while ago with top oven not heating. one month ago lower oven would take 15 minutes to heat up. After staying at 100 degrees for 15 minutes or so it would start to heat and go right upp to temp. Now lower or upper oven heat up at all. stays right at 100 degrees. Anybody with any thoughts.:( Thank you,
There are three igniters: two (Bake & Broil) in the upper oven and one (Bake) in the lower oven. The first thing I would do is check for 120VAC to each of the igniters while the control calls for heat in the corresponding mode. Run this test and post the results.
Originally Posted by: stevevidmar ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Have a maytag double oven. trouble while ago with top oven not heating. one month ago lower oven would take 15 minutes to heat up. After staying at 100 degrees for 15 minutes or so it would start to heat and go right upp to temp. Now lower or upper oven heat up at all. stays right at 100 degrees. Anybody with any thoughts.:( Thank you, Thank you forgot to reply until now but working great that was the problem. All three ignitors went out basically at the same time
You are welcome. Thank you for the feed back. It's not often we see all three igniters failed at the same time. Good luck with your oven.
