All heating element working but no display board n oven working.
Here are your parts. Parts for Whirlpool YKESS907SS00 Range - AppliancePartsPros.comSo everything works except the display. Sounds like a problem with the control board (item 3 in section 02). It looks like this is a fluorescent display and often it is a problem with one of the electrolytic capacitors on the back of the board. I do not know which one so just replace all of them. Be sure to note their polarity before replacing them. This works in about 80% of the cases. Or just replace the board. |
THIS FORUM IS DEAD!!!!!!! |
