jamesbeau
#1 Posted : Thursday, June 12, 2014 9:30:13 AM(UTC)
jamesbeau
This fridge went into defrost and did not come out, the mullion bar ( across the two freezer drawers) got very warm and fans ran but did not hear compressor. i thought bad evap thermistor or defrost thermostat so I replaced them. No joy. on reading everyone and repair manual said if not those two then control board, so under protest I replaced control board. Compressor kicks on for a few seconds and seems to just lose power. I have 119 vac and around 5 vdc ( it bounces 4.9 to 5.45) to inverter so I assume that is power signal. On physical inspection inverter shows some temperature discoloration but no burn. I do not want to just replace the inverter to find this 7 year old compressor is bad. Any advice would help.thank you for your time James for Model Number GE PGCS1PJXASSVM
jamesbeau
#2 Posted : Thursday, June 12, 2014 7:20:18 PM(UTC)
jamesbeau
so I am sitting next to this fridge for an hour or more and noticed, a relay clicking once every 10 minutes and the compressor doing it's thing a minute or three later. thanks again for any help
james
#3 Posted : Friday, June 13, 2014 1:32:18 AM(UTC)
If the compressor vibrates, then shuts down on the inverter overload, you probably have a bad compressor, amprobe would confirm.
jamesbeau
#4 Posted : Friday, June 13, 2014 5:10:45 AM(UTC)
jamesbeau
ok the compressor sounds like it is powering up then goes silent, this is a variable speed compressor and I am not sure about what my amp reading should be, also should I use a clamp on inductive ammeter on each wire or in series with jumpers? also three wires go to the compressor none marked is variable speed compressor wired different from standard compressor?
#5 Posted : Friday, June 13, 2014 1:26:51 PM(UTC)
You must find the power wires to the inverter per. the schematic. Clamp an amprobe on the hot wire, usually black, single phase current would normally be around 1.3 to 1.6 amp. If it checks out, you probably have a bad inverter, unless the power goes away for some reason from the control.
Frige not cold enough freezer fine+fix? (Refrigerator & Freezer Repair)
by tomsap 5/8/2022 2:02:41 PM(UTC)
freezer cold,fridge not cold enough (Refrigerator & Freezer Repair)
by BSTrue 11/18/2018 2:40:04 AM(UTC)
Fridge Not cold enough (Refrigerator & Freezer Repair)
by water101 1/10/2018 8:28:55 PM(UTC)
Kenmore fridge not cold enough (Refrigerator & Freezer Repair)
by benbenherenow 4/9/2015 1:26:32 PM(UTC)
Fridge not cold. Freezer ok (Refrigerator & Freezer Repair)
by PURCHIARONI@ATT.NET 3/7/2015 12:27:16 PM(UTC)
Freezer fine, Fridge not cold (Refrigerator & Freezer Repair)
by WWats004 1/9/2015 7:44:09 AM(UTC)
Freezer & Fridge not cold - coils cold, evap fan works but not running (Refrigerator & Freezer Repair)
by bootpdx 1/6/2015 9:51:56 AM(UTC)
by agdodge4x4 8/3/2014 7:04:28 AM(UTC)
Kenmore freezer cold, fridge not cold (Refrigerator & Freezer Repair)
by bc. canuck 7/8/2014 9:06:32 AM(UTC)
SxS fridge not cold & shuts off (Refrigerator & Freezer Repair)
by 77bravo 6/3/2014 1:03:00 PM(UTC)
Freezer frosting over, fridge not cold (Refrigerator & Freezer Repair)
by spowel007 4/5/2014 2:20:16 PM(UTC)
Freezer And Fridge Not Cold Enough - GE Profile Arctica (Refrigerator & Freezer Repair)
by lakeober 7/14/2013 8:43:21 PM(UTC)
Frigidaire Freezer working, Fridge not cold (Refrigerator & Freezer Repair)
by jalill 11/27/2012 4:40:19 AM(UTC)
Freezer vents covered with ice/ fridge not cold (Refrigerator & Freezer Repair)
by amytorp 11/1/2012 1:16:35 PM(UTC)
frezzer back freezing up- fridge not cold (Refrigerator & Freezer Repair)
by murphy7513 10/4/2012 10:09:15 AM(UTC)
