mgmills
#1 Posted : Sunday, June 8, 2014 7:58:45 AM(UTC)
mgmills
The door on our Whirlpool Quiet Partner III dishwasher does not lay flat when opened. It remains opened at an angle and quite annoying. Does the door spring need to be replaced? Any advice is welcomed. Thanks.
#2 Posted : Tuesday, June 10, 2014 2:50:38 AM(UTC)
It does not sound like a spring problem.
Check you manual as the spring may just need adjusting.
Also check that the unit is installed level.
Need replacement control panel for Whirlpool Quiet Partner III (Dishwasher Repair)
by teewhile 1/18/2022 6:59:40 PM(UTC)
Whirlpool Quiet Partner III GU2400XTPS6 on but only runs the drain pump (Dishwasher Repair)
by misterbrokeit 10/31/2020 1:14:40 PM(UTC)
Whirlpool Quiet PArtner III leaking underneath (Dishwasher Repair)
by KareeHunt 8/26/2020 8:26:37 AM(UTC)
Whirlpool Quiet Partner iii stuck in wash cycle (Dishwasher Repair)
by WaltP 4/19/2020 9:47:42 AM(UTC)
Whirlpool Quiet PArtner III Pot/Pan light on and dishwasher will not run (Dishwasher Repair)
by DJ Chaffers 1/2/2016 6:13:21 PM(UTC)
Whirlpool Quiet Partner III gets stuck on a Normal cycle (Dishwasher Repair)
by jessman1128 10/27/2014 9:09:10 PM(UTC)
Whirlpool Quiet Partner III help (Dishwasher Repair)
by sjde 9/10/2014 4:42:56 PM(UTC)
Whirlpool Quiet Partner III - Door is loose; drops quickly; doesn't stay down (Dishwasher Repair)
by ESticker 7/2/2014 4:11:59 PM(UTC)
by tinymrf 8/21/2013 1:02:57 PM(UTC)
Whirlpool Quiet Partner III thermal fuse blew after replacing heater element (Dishwasher Repair)
by dieseldaddy 6/4/2013 4:40:34 PM(UTC)
whirlpool quiet partner III blinking lights (Dishwasher Repair)
by rwhans007 11/27/2012 1:09:54 PM(UTC)
Whirlpool Quiet Partner III Won't Start (Dishwasher Repair)
by hendricksd 10/23/2012 12:28:03 PM(UTC)
WhirlPool Quiet PArtner III (Dishwasher Repair)
by jbrantl8 9/4/2012 4:54:21 AM(UTC)
No lights on Whirlpool Quiet Partner III (Dishwasher Repair)
by johnctln 8/14/2012 6:59:27 AM(UTC)
by Leamei 2/29/2012 7:15:32 PM(UTC)
