varover
#1 Posted : Tuesday, May 27, 2014 11:30:53 AM(UTC)
varover
Views messages in topic : 3
We had a basement flood and got 6 inches of water…right up to where the relay is on the side of the compressor. Didn't notice until cleaning up that the freezer was running but not getting cold. When I checked it out, the compressor was very hot. I got what was supposed to be a compatible replacement relay and overload kit, installed it, and no joy. The compressor no longer runs hot, and though it does seem to be running, it's still not making cold. The starter relay I installed (an ER8201799) that was supposed to fit this model is visibly not the exact same relay as what came out (an 8EA14C3)…but I don't know if they're compatible anyway. The kit also came with two different overload switches that the instructions say are differentiated by the sq footage of the freezer model, (my freezer is not the size they listed for either overload). But, I've tried both with no success. I'm pretty ignorant of the relays…even though the compressor seems to be on and running…I can feel it anyway…could the wrong relay be still to blame, or is it more likely that the flood damaged something else that is less obvious?
#2 Posted : Tuesday, May 27, 2014 12:59:12 PM(UTC)
Is the compressor warm and vibrating?
varover
#3 Posted : Wednesday, May 28, 2014 8:19:41 AM(UTC)
varover
Vibrating: yes, warm: not so much. Before I replaced the relay, it was very hot. Now, I'd say it gets warm, but it hasn't gotten hot. I've had it off and just plugged it back in so that's why it's not even warm right now.
#4 Posted : Wednesday, May 28, 2014 8:25:14 AM(UTC)
Seems like it developed a refrigerant leak assuming the compressor is running/vibrating.
varover
#5 Posted : Wednesday, May 28, 2014 2:38:26 PM(UTC)
varover
On the one hand, nothing much surprises me…on the other hand, seems like a weird side-effect of being flooded. I should have mentioned that this freezer is just about 1 yr old. So, relatively new. What's the likelihood that the relay is not passing enough amps to get it to cold? Or could the running hot the way it did cause it to generate a leak? I would tend to agree with you that it seems like it's lost coolant, but then I don't know enough to know different either!
#6 Posted : Thursday, May 29, 2014 1:36:49 AM(UTC)
You can try a new start device, or pull the freezer back panel. If you see a little frost, it's low on refrigerant.
Kenmore (Amana) 596.79142993 Refrigerator & Freezer not getting cold enough (Refrigerator & Freezer Repair)
by Guest 8/23/2021 12:17:10 PM(UTC)
Freezer not getting cold enough to freeze water/ice cubes (Refrigerator & Freezer Repair)
by Steve_K_163 4/6/2021 4:11:28 PM(UTC)
Maytag refrigerator & freezer not getting cold (Refrigerator & Freezer Repair)
by jer1989 11/12/2016 12:10:43 PM(UTC)
Freezer Not Getting Cold Enough! (Refrigerator & Freezer Repair)
by kag716 10/4/2016 5:40:27 PM(UTC)
Freezer not getting cold enough, Fridge Fine, my use is atypical though (Refrigerator & Freezer Repair)
by jamisonia 7/14/2014 8:53:17 AM(UTC)
Fridge & freezer not getting cold (Refrigerator & Freezer Repair)
by Mandirigma 4/26/2014 3:59:09 AM(UTC)
ge upright freezer not getting cold enough (Refrigerator & Freezer Repair)
by Wwb1969 11/26/2013 10:46:44 AM(UTC)
Upright Freezer Not Getting Cold (Refrigerator & Freezer Repair)
by R4665 10/11/2013 8:28:30 PM(UTC)
freezer not getting colder than 17 degrees (Refrigerator & Freezer Repair)
by strat1953 5/19/2013 4:10:22 PM(UTC)
Freezer Not getting cold enough (Refrigerator & Freezer Repair)
by Spanky84 12/24/2012 1:58:52 PM(UTC)
Freezer not getting cold (Refrigerator & Freezer Repair)
by elknuts 10/8/2012 11:08:27 AM(UTC)
Fridge and freezer not getting cold (Refrigerator & Freezer Repair)
by DaveDaveDave1 10/3/2012 2:55:58 PM(UTC)
Fridge and freezer not getting cold. (Refrigerator & Freezer Repair)
by Dduncan18 6/26/2012 11:17:53 AM(UTC)
refrigerator/freezer not getting cold (Refrigerator & Freezer Repair)
by cj2569 5/31/2012 4:10:48 PM(UTC)
fridge & freezer not getting cold (Refrigerator & Freezer Repair)
by Ricky2012 3/15/2012 3:48:58 PM(UTC)
