Fridge and freezer not getting cold. Compressor not running. Hear clicking sound. Any ideas?
THIS FORUM IS DEAD!!!!!!! |
Never hear the compressor actually try to kick on. Just hear a click every so often. I do hear a timer running by the light bulbs in the fridge continuously.
Try turning the cam on the defrost timer to see if it will fire up. There is usually a hole in the cover that allows you to do this without taking anything apart. Perhaps you are stuck in a defrost cycle.
Take the rear cover off and see if the click is coming from the compressor's start device. |
