npreese
#1 Posted : Thursday, May 7, 2009 1:16:06 PM(UTC)
npreese
I have this dryer I got and it looks like someone tried to remove the 4 prong plug and put a 3 prong plug in, Well I dont know if they did it wrong but the breaker is blown and I want to know if anyone has this same dryer and could send me a picture of what wires go to the black and which to the red. PLEASE HELP!!!
#2 Posted : Thursday, May 7, 2009 1:57:55 PM(UTC)
Replacement parts for MAYTAG MDE7500AYQ | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/m...ibrary/docs/16023110.pdf
Not quite sure what you are trying to do re: use a 3 prong or a 4 prong plug.
To go from a 4 to a 3, the Neutral is connected to the terminal block and this is also connected to the frame by a ground strap. On a 4 wire the Neutral is connected to the center terminal (usually), the ground strap is removed and the earth ground wire (usually green or bare wire) is connected to the frame.
Neutral = White
L1 = Black
L2 = Red
Ground = Green or bare wire
npreese
#3 Posted : Thursday, May 7, 2009 2:08:23 PM(UTC)
npreese
Thank you so much!! I want it to be a 3 prong so I can hook it up to my house. But here is the thing. I think they tried to do it before I got it and I want to make sure I have the wires from the dryer going to the right ones on the cord. I know the whites are ground but do the 2 blues hook up to the black and the purple and black hook up to the red? They must have got it wrong before because the breaker in the machine was blown. So I am going to order a new one and wanted to make sure I had the wiring correct before plugging it in.
#4 Posted : Thursday, May 7, 2009 2:30:43 PM(UTC)
The way I read the wiring diagram.
The 2 BLUES are L2 so should be Red
The BLACK & PURPLE are L1 should be Black
That being said it should not make any difference.
What is important is that the ground strap from White to the frame be installed. Otherwise if L1 or L2 should short to the frame, the frame becomes live, touch it and a ground (the water tap etc.) and you will get shocked.
I would install the line cord and then check the prongs on it with a meter for resistance. Using the most sensitive setting. If you see 0 ohms then you still have a short.
Looking to tune up our Maytag Neptune Dryer (Dryer Repair)
by bassett72 2/14/2018 4:51:00 AM(UTC)
by 3pinballs 9/10/2014 11:33:08 AM(UTC)
how to take apart front face of maytag neptune dryer to get to coils (Dryer Repair)
by m218perez 6/18/2014 12:25:10 PM(UTC)
Maytag Neptune Dryer LOUD High Pitch Screeching (Dryer Repair)
by audioarch 2/28/2014 3:53:13 PM(UTC)
Small Paint Brush Stuck in Maytag Neptune Dryer Lint Trap (Dryer Repair)
by PVBSJ 11/20/2013 5:57:47 PM(UTC)
Maytag Neptune Dryer Doesn't Start on /off (Dryer Repair)
by torrealtl1 11/13/2013 9:39:51 AM(UTC)
Maytag Neptune Dryer doesn't work (Dryer Repair)
by pulsar2121 11/3/2013 3:41:03 PM(UTC)
maytag neptune dryer issues (Dryer Repair)
by blueovalfever 10/14/2013 6:25:43 AM(UTC)
Maytag Neptune Dryer wont do anything (Dryer Repair)
by heg0423 8/21/2013 10:26:37 PM(UTC)
Maytag Neptune Dryer not starting (Dryer Repair)
by buckeye597 2/17/2013 4:09:06 PM(UTC)
Need Service Repair Manual Maytag Neptune Dryer MDE4000AYW (Dryer Repair)
by Paul02 8/12/2012 2:21:22 PM(UTC)
by roylance 7/19/2012 1:04:11 PM(UTC)
Maytag Neptune Dryer Code FE (Dryer Repair)
by hamrepairman 7/6/2012 6:28:38 PM(UTC)
Maytag Neptune Dryer - heat will not stay on (Dryer Repair)
by creeker69 5/24/2012 6:51:55 PM(UTC)
by crutecaroline 2/11/2012 8:46:12 AM(UTC)
