fudge2009
#1 Posted : Saturday, April 26, 2014 3:49:14 AM(UTC)
fudge2009
need wiring diagram ,thanks refridge dead no lights nothing
#2 Posted : Sunday, April 27, 2014 6:33:03 AM(UTC)
Sorry but I cannot find any tech info n this unit.
You could try Googling the model number, one thing to note is that the last digit is a zero not an "o".
I am assuming that you have already checked the wall out let for 120 volts.
Next would be to check the units line cord.
fudge2009
#3 Posted : Monday, April 28, 2014 2:54:39 AM(UTC)
fudge2009
getting correct voltage at junction box part # 549945, but does not seem to be going thru this box changed box same results. need pin diagram for box, if I jump compresser ,evap fan they both work
fudge2009
#4 Posted : Monday, April 28, 2014 2:59:20 AM(UTC)
fudge2009
getting correct voltage at junction box part # 549945, but does not seem to be going thru this box changed box same results. need pin diagram for box, if I jump compresser ,evap fan they both work seem like a line problem on line side of box or maybe wired wrong
#5 Posted : Tuesday, April 29, 2014 2:40:42 AM(UTC)
Attached is a wiring diagram for a EHD192 unit.
It uses the same junction box
I hope it will be useful to you.
I cannot say how close of a match it is to yours but at least it should give you an idea how they wired the units back then.
File Attachment(s):
EHD192.pdf (238kb) downloaded 3 time(s).
fudge2009
#6 Posted : Tuesday, April 29, 2014 5:30:19 AM(UTC)
fudge2009
thanks i'll check it out with ohm metet
#7 Posted : Tuesday, April 29, 2014 5:41:01 AM(UTC)
I would start tracing the black wire.
The white seems to be connected to a number of parts directly so it does not make sense that they would all go bad at the same time.
The black looks like it routs by itself so if it is a bad wire or connection/junction further on in the unit it could kill everything.
fudge2009
#8 Posted : Wednesday, April 30, 2014 1:25:26 PM(UTC)
fudge2009
ok thanks i'll start tracing that wire
Guest (8)
Need wiring diagram for Duet GHW9150PW1 (Washer Repair)
by Conesus 12/14/2022 10:50:49 AM(UTC)
Need wiring diagram for heating element/thermal fuse/hi-temp fuse forAmana ALE643RAW. (Dryer Repair)
by mdjetdoc 1/13/2016 11:31:57 AM(UTC)
Need Wiring Diagram for Whirlpool Gas Dryer (Dryer Repair)
by ToddErickson 2/2/2015 4:11:08 PM(UTC)
need wiring diagram (Oven Repair (including Ranges and Cooktops))
by tylerlee 8/10/2013 5:19:23 PM(UTC)
need wiring diagram (Dryer Repair)
by rva-fixit 7/28/2013 6:59:31 AM(UTC)
Need wiring diagram for this refer (Refrigerator & Freezer Repair)
by nan1112 7/26/2013 3:47:47 AM(UTC)
Need wiring diagram (Oven Repair (including Ranges and Cooktops))
by Charliez 12/17/2012 3:26:15 PM(UTC)
Need wiring diagram for GE dryer (Dryer Repair)
by rick88ss 10/22/2012 7:55:10 PM(UTC)
need wiring diagram for magic chef furnace and ac unit with robertshaw gas valve and (Heating, Ventilation, and Air Conditioning (HVAC))
by bigdaddy88 8/2/2012 4:16:30 PM(UTC)
Need wiring diagram (Dryer Repair)
by Rick41 5/1/2012 8:06:34 AM(UTC)
wiring disconnected from timer, need wiring diagram (Dryer Repair)
by Chip65 12/2/2011 2:51:45 PM(UTC)
Need wiring diagram for Kenmore 400 series dryer (Dryer Repair)
by MarthaV 7/15/2011 8:03:59 AM(UTC)
need wiring diagram for fridge (Refrigerator & Freezer Repair)
by misterfixall 5/5/2011 4:55:11 AM(UTC)
Need wiring diagram. Help. (Refrigerator & Freezer Repair)
by justin99 2/25/2011 9:13:19 AM(UTC)
Need wiring diagram (Heating, Ventilation, and Air Conditioning (HVAC))
by MagicMan 5/27/2010 6:23:27 AM(UTC)
