Skeeteri
#1 Posted : Thursday, April 3, 2014 5:42:37 PM(UTC)
Skeeteri
Four days ago my dryer quit drying clothes. Everything worked fine except I had no heat. I tested the components with my meter and found out the high temperature cut out was bad. I replaced part and now my heating element stays on. Element will turn off if i turn setting to air fluff. Element tests at 10 ohms and is infinite on each side of the coil to the frame. I took out element and could not find anywhere it was touching the housing. Any ideas? thanks for the responses
#2 Posted : Friday, April 4, 2014 2:09:10 AM(UTC)
I think the model number you posted is a part number.
Please post the model number.
Find your model number - AppliancePartsPros.com
Could be the cycling thermostat is not opening.
Also on most units when the thermal cut-off is blow you also have to replace the high limit thermostat. The cut-off is a backup device for the high limit.
Dryer Heating Element Stays on during cool down and air dry (Dryer Repair)
by Ron.Easterling 10/9/2017 2:16:54 PM(UTC)
Maytag LDE412 heating element stays on (Dryer Repair)
by kandpand 3/15/2014 3:20:06 AM(UTC)
Heating element stays on (Dryer Repair)
by kfiles 1/31/2011 8:37:44 PM(UTC)
Heating element stays on - all settings (Dryer Repair)
by Brian A 6/21/2009 2:09:57 PM(UTC)
Maytag Heating Element stays on (Dishwasher Repair)
by cwbyfam 5/26/2009 3:49:30 PM(UTC)
Heating Element Stays On In Cool Down (Dryer Repair)
by OLDGUYDIY 10/28/2008 6:56:17 AM(UTC)
