beachboy
#1 Posted : Tuesday, May 5, 2009 1:20:56 PM(UTC)
beachboy
While drying a pair of sneekers the drum got jammed and now will not tumble
sidfink43
#2 Posted : Wednesday, May 6, 2009 8:13:59 AM(UTC)
sidfink43
You are going to have to open up the machine and see if the belt is broken, or if the drum is jammed up on the rollers.
If you want additional help, please post the model number and let us know what you found when you opened up the dryer.
Good luck,
dryier drum wont turn when clothes are put in, with cloths te dryier will run (Dryer Repair)
by jklimuszka 12/7/2012 3:25:03 AM(UTC)
drum wont turn with a normal load (Dryer Repair)
by fred bruning 4/25/2012 10:42:17 AM(UTC)
LG Front Load-LE Code- Drum wont turn (Washer Repair)
by sleddoc 5/3/2011 5:51:12 AM(UTC)
gas dryer drum wont turn (Dryer Repair)
by mpeccleston 10/24/2010 7:54:23 AM(UTC)
Front Loader drum wont turn (Washer Repair)
by jtoddrn 4/10/2010 8:14:11 AM(UTC)
admiral dryer..drum wont turn (Dryer Repair)
by PJfuture 11/25/2009 6:47:13 AM(UTC)
by Reenie50 8/19/2008 8:03:14 AM(UTC)
