ron1821
#1 Posted : Monday, March 24, 2014 4:57:26 PM(UTC)
ron1821
wont spin with loads, spins with no load, new clutch put in recently.
should i be able to spin the tub both ways by hand when unplugged? Seems to be locked as i hear a clunk when trying to spin?
any ideas thanks.
mr_mjsjr
#2 Posted : Monday, March 24, 2014 6:18:30 PM(UTC)
mr_mjsjr
you need to look closer to what is happening. put in a load of towels. is there any knocking, do you see any odd movement w/ agitator/basket(the hub may be loose or the nut holding the basket may have broken or come loose{that nut is reverse thread}). when the motor spins does the clutch pulley/belt/gear case pulley/ gear case turn? if the motor turns and the clutch pulley does not, it is the clutch. if the clutch pulley turns and the belt does not, it is the belt. if the belt turns and the gear case pulley does not, it is connection between the pulley and gear case. if the pulley turns and the gear case does not it, is the gear case. now we are back up to the basket.
fairbank56
#3 Posted : Tuesday, March 25, 2014 4:34:30 AM(UTC)
fairbank56
Groups: Expert
And you should not be able to rotate the tub by hand.
Eric
ron1821
#4 Posted : Tuesday, March 25, 2014 5:18:15 PM(UTC)
ron1821
everything seems to be moving correctly. the agitator is loose. I can move it up and down/back and forth about an inch eachway. guess I will have to take agitator and basket off to look eh?
thanks for your help i really appreciate it
GE profile washer wont spin (Washer Repair)
by ron1821 3/19/2014 11:31:36 AM(UTC)
GE profile Washer Wont spin at all (Washer Repair)
by llamas1 4/28/2013 6:59:28 AM(UTC)
ge profile washer wont spin or agitate (Washer Repair)
by mstrchief 10/16/2009 5:52:45 PM(UTC)
GE Profile washer wont spin or agitate (Washer Repair)
by volguy 6/10/2009 4:05:06 PM(UTC)
