jdbell1114
#1 Posted : Monday, March 17, 2014 5:58:20 PM(UTC)
jdbell1114
Rank:: Member
Dryer finished cycle then wouldn't start again. The timer runs. I have check continuity of the thermal fuse and the start button. All checks out ok. Any recommendations as to what to look for next>
#2 Posted : Tuesday, March 18, 2014 1:16:26 AM(UTC)
You are missing several digits at the end of your model number.
I think the attached is the correct wiring diagram.
I would check the start circuit.
Set the timer to mid cycle timed dry.
Unplug the unit.
Attach one meter lead to the L1 prong on the line cord and leave it there.
Use you most sensitive meter scale. Also short the meter leads together before starting so you can see if the meter has a zero offset.
Now work your way back through the start circuit.
L1 to BK and BU on the timer should be 0 ohms.
Blue/black or may be just blue on the start switch should be 0 ohms.
Light blue on the start switch should be 0 ohms with the switch pressed.
Keep the switch pressed,
Both sides of the thermal fuse should be 0 ohms.
4M at the motor's centrifugal switch should be 0 ohms.
5M (white) at the motor should be about 1.5 ohms.
Timer contacts for Timer Switch 4 (W and T) should both be 1.5 ohms.
Both sides of the door switch should be 1.5 ohms.
Neutral at the terminal strip and line cord prong should be 1.5 ohms.
There that is the start circuit checked.
With luck you will find the problem part/connection.
File Attachment(s):
WED5300.pdf (96kb) downloaded 12 time(s).
appliancecowboys
#3 Posted : Wednesday, March 19, 2014 2:01:38 AM(UTC)
appliancecowboys
Your Whirlpool dryer may not start may be because the dryer door is not shut properly. The dryer won't run if the door is slightly ajar, and heavy loads may prevent it from closing completely. If you are still unable to solve the problem you may need to ask the assistance of an appliance repair service.
#4 Posted : Wednesday, March 19, 2014 2:16:57 AM(UTC)
If it is a door switch problem then the timer will not advance in timed dry cycles.
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
Whirlpool Dryer Won't Start- Help! (Dryer Repair)
by NikTy15 5/3/2015 6:59:24 AM(UTC)
Whirlpool dryer won't start (Dryer Repair)
by cmarley304 8/19/2014 6:07:34 PM(UTC)
by emontoute 8/4/2013 10:01:22 AM(UTC)
by Turtleman1961 1/18/2013 5:52:20 PM(UTC)
Whirlpool Dryer won't start (Dryer Repair)
by adsch 6/26/2012 7:55:27 PM(UTC)
Whirlpool Dryer won't start - buzzing (Dryer Repair)
by David Mitchell 1/14/2012 11:52:35 AM(UTC)
by gunworks 12/14/2011 6:47:15 PM(UTC)
by patarnotte@comcast.net 12/6/2011 1:57:13 PM(UTC)
Whirlpool Dryer won't start, but hums (Dryer Repair)
by gmreeves2 12/1/2011 8:16:57 PM(UTC)
by JWCL 11/29/2011 6:43:51 AM(UTC)
by moonie777 5/13/2011 8:59:04 AM(UTC)
by zebra47cb 2/24/2011 2:53:01 PM(UTC)
Whirlpool Dryer won't start in dryer mode. (Dryer Repair)
by hol99 12/24/2010 1:06:56 PM(UTC)
by hol99 12/15/2010 8:39:33 PM(UTC)
