The amount of water coming from the sprayers seams very low as witnessed with the door open. I watched it for 20 minutes of the pots and pans cycle, and the spray power was low from either of the three sprayers. In fact they barely rotated.
How can I increase the water pressure?
ensure you have enough water in the unit, pump could cavitate. your impeller may be damaged or the screen is blocked slowing down water flow
Even after I added 1.5 gallons water more I has as the same results.
