chugalug
#1 Posted : Tuesday, March 11, 2014 12:27:15 PM(UTC)
chugalug
I have changed control board and the board on the front not getting no codes.But the elements are not getting hot
#2 Posted : Wednesday, March 12, 2014 1:38:06 AM(UTC)
Parts for Whirlpool RBS275PDQ14 Wall Oven - AppliancePartsPros.com
I am assuming that the unit stays in preheat and never comes ready.
If it does then it could be the oven sensor.
You will have to pull the unit and check the Thermal Fuse (item 37 in section 01). It should be 0 ohms.
Also check that the oven is getting 240 volts.
File Attachment(s):
RBS275.pdf (169kb) downloaded 3 time(s).
Upper elements not working - Whirlpool GBD307PDB5 (Oven Repair (including Ranges and Cooktops))
by houtxfdcapt 8/6/2023 2:19:45 PM(UTC)
Amana AER6303MFB2 stove elements not working correctly (Oven Repair (including Ranges and Cooktops))
by r_pnw 6/16/2022 12:09:07 PM(UTC)
Frigidaire oven - bake and broil elements not working (Oven Repair (including Ranges and Cooktops))
by wife2004 9/21/2015 5:51:02 PM(UTC)
oven elements not working (Oven Repair (including Ranges and Cooktops))
by giroux68 12/6/2014 11:43:55 AM(UTC)
Kitchenaid bake and convection elements not working (Oven Repair (including Ranges and Cooktops))
by ColdOven 11/26/2013 9:58:20 PM(UTC)
fisher paykel double oven top oven and broiler elements not working (Oven Repair (including Ranges and Cooktops))
by milo77 11/15/2013 9:17:53 AM(UTC)
by korean1 4/22/2013 1:33:32 PM(UTC)
One of the Two Broiler Elements Not working Kitchenaid KEM378s (Oven Repair (including Ranges and Cooktops))
by alfalover 3/1/2013 4:13:06 PM(UTC)
Heating Elements Not Working (Dryer Repair)
by Luketuomenoksa 7/21/2012 6:51:49 PM(UTC)
Heating Elements Not Working (Oven Repair (including Ranges and Cooktops))
by brooksb 5/1/2012 9:11:54 AM(UTC)
Oven does not heat / elements not working (Oven Repair (including Ranges and Cooktops))
by Steve Dyr59 3/8/2012 3:20:24 AM(UTC)
both elements not working (Oven Repair (including Ranges and Cooktops))
by dodalu 1/9/2011 12:50:26 PM(UTC)
Bake and Broil heat elements not working (Oven Repair (including Ranges and Cooktops))
by spiriteenie 4/30/2010 11:20:46 AM(UTC)
Elements not working after running self-clean (Oven Repair (including Ranges and Cooktops))
by lusien 4/6/2010 10:59:23 AM(UTC)
Oven bake or broil elements not working (Oven Repair (including Ranges and Cooktops))
by reginald jones 11/4/2009 8:06:59 AM(UTC)
