degrange
#1 Posted : Saturday, February 22, 2014 8:16:51 AM(UTC)
degrange
In normal use, the Start button does not light up. In I use the Service Diagnostics Cycles Notes, the Start button does light up, but the Heated Dry button does not light up.
Do I need a new control panel or control board?
Thanks.
festeraddams
#2 Posted : Saturday, February 22, 2014 7:11:48 PM(UTC)
festeraddams
On these Whirlpool built models the main issue would be with the control panel (the keypad), The main PCB is usually fine and not at fault....
degrange
#3 Posted : Tuesday, February 25, 2014 8:58:15 AM(UTC)
degrange
Okay. Since the Start button works in 1 mode, but not in the other< iwas thinking it was the Control Board. Thanks.
festeraddams
#4 Posted : Wednesday, February 26, 2014 4:42:59 PM(UTC)
festeraddams
Sounds like the light was working but the button was dead....?????
Is it the control panel or control board (Dishwasher Repair)
by bluefitness 5/13/2013 5:11:42 PM(UTC)
Control Panel or Control Board (Dishwasher Repair)
by lesmiles 1/23/2012 7:35:46 AM(UTC)
