After cycle and I remove dishes from dishwasher I close the door and it keeps running. Called a repair guy to come fix and he removes the door and says connector were loose. Worked fine for a couple days and it does the same thing so I remove the door and wiggle the connectors and it starts working fine again for a couple of days. Been doing this routine for over a month now. Can anyone help?
What connectors? Picture?
The connectors that connect into the latch assy.
May need a new latch assembly possibly....
