I have a Kenmore dryer m/n 110.76822694. It has beeen drying intermittently now for the past week. I read some posts about the valve coils and replaced. Seemed fine at first but now the ignitor coil is no longer coming on when pushing the start button. I measured the coil and got 63 ohms, will check the flame sensor next. Any other suggestions and would you have a schematic for the wiring, couldn't find anything inside the unit. Thanks
Groups: Expert
Here's your wiring diagram. With timer on, check for 120vac to ground at blue wire on thermal fuse. Igniter should read about 40 ohms at room temp. Eric ![UserPostedImage](http://home.comcast.net/~fairbank56/11076822694%20wiring%20diagram.jpg)
Thanks, this will help a lot!
