diyeng
#1 Posted : Monday, February 24, 2014 10:01:39 AM(UTC)
diyeng
I have a Kenmore dryer m/n 110.76822694. It has beeen drying intermittently now for the past week. I read some posts about the valve coils and replaced. Seemed fine at first but now the ignitor coil is no longer coming on when pushing the start button. I measured the coil and got 63 ohms, will check the flame sensor next. Any other suggestions and would you have a schematic for the wiring, couldn't find anything inside the unit.
fairbank56
#2 Posted : Monday, February 24, 2014 2:03:16 PM(UTC)
fairbank56
Groups: Expert
Here's your wiring diagram. With timer on, check for 120vac to ground at blue wire on thermal fuse. Igniter should read about 40 ohms at room temp.
Eric
UserPostedImage
diyeng
#3 Posted : Tuesday, February 25, 2014 7:10:42 AM(UTC)
diyeng
Thanks, this will help a lot!
Kenmore Gas dryer intermittent flame (Dryer Repair)
by jfox 8/21/2010 2:58:11 PM(UTC)
